Router Replacment Problem
Feb 4th, 2008
I want to replace a faulty router with new one,i did all configuration as the old one,attached the new and it is not working,this is the configuration of both. I do apprecite any help.
Goutam Sanyal Tue, 02/05/2008 - 00:15
post the details - what is not working exactly? Or you can check the Ports (Serial/fast-Giga Ethernet) are not administratively down.
Please rate if it works
aijaz802 Tue, 02/05/2008 - 02:21
Also check the serial interfaces. The interface numbers might not be matching with the physical connections.
Rate if this works....
Danilo Dy Tue, 02/05/2008 - 03:40
Thus the faulty router and replacement router the same model and running the same IOS version/feature set?
Take note that if the model is different, module slot/interface number may differ. Also, if the model is different, module from the old router may not be compatible to the replacement router (i.e. firmware/release verion).
If the IOS version/feature set is different, some configuration lines from the faulty router may not be available in the replacement router.
