PIX 506E traffic forwading problem
Feb 5th, 2008
Hi all,
We are using 1 PIX 506E and 1 2611 router, 1 3560-L3 switch.now i want to forward traffic from switch to PIX and then PIX to ROuter.i have connect pix & switch through 10.xx.xx.xx series ip and pix to router through 192.168.xx.xx series ip. from host or switch i m able to ping pix's inside interface but not to outside interface. from router also i can ping pix's outside ip but not to the inside ip. pls help us on this ASAP.ist very urgent.
srue Tue, 02/12/2008 - 07:37
you can't ping the far side interface of a pix or asa...ever.
you can ping hosts on the other side of a pix/asa though - just follow the aforementioned link.
(you just have to allow echo-replies from the hosts you're trying to ping).
from an inside host, you should be able to ping the router though, once you allow echo-replies back into the network.
to ping from outside to inside, allow echo's into the network.
