VPN IPSec problem with ISA Server
lformelli
I have deployed an a VPN IPSec L2L from
ASA 5505 with peer firwall ISA Server Microsoft.
I see that this tunnel is unstable enough.
Does someone know if there is some problem about or advice me something ?
best regards
Lorenzo
5 Replies 5
hadbou
Level 5
Level 5
Make sure the Crypto Access List matches on both the sides. This issue has troubled me in getting the stable tunnel. Refer URL http://cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml for general troublesooting.
mark.white
Hello:
We have run across this issue two times and the solution has been the same. When trying to establish a VPN with an ISA server on their end, you need to (for some strange reason) add the actual peer address of the ISA server to the encryption domains of the VPN tunnel. Example:
access-list 104 permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list 104 permit ip 192.168.1.0 255.255.255.0 host 1.1.1.1
crypto map mymap 8 set peer 1.1.1.1
Hope this helps.
Hi Mark,
Is 192.168.1.0 network address behind ASA ?
Is 1.1.1.1 public address of ISA Server ?
Is 192.168.100.0 network address behind ISA Server ?
I have now:
access-list outside_20_cryptomap extended permit ip 192.168.18.0 255.255.255.0 host Ip_Peer
access-list outside_20_cryptomap extended permit ip 192.168.18.0 255.255.255.0 intranet 255.255.255.0
crypto map outside_map 20 set peer Ip_Peer
where IP_Peer is address public of ISA
and intranet in network address behind ISA.
192.168.18.0 i network address behind ASA.
I think to have already configure like you
suggest me.
It's true ?
best regards
Lorenzo
Where:
192.168.1.0 255.255.255.0 - Your local domain
192.168.100.0 255.255.255.0 - Remote domain
It looks as if the order of ACEs maybe an issue. I believe you should switch the two lines. I haven't tried it the way you have written it. I've only written the ACL as stated above. I'm a strong believer of "If ain't broke, don't fix it!" :)
Does this clear it up for you?
lformelli
have you deployed this ACE on a ASA 5505 ?
If so,
have you not enter any access-group 104 about ?
best regards
Lorenzo
