markduffield Tue, 02/05/2008 - 09:30
Does anybody know if there is a way to remove the "Intercom History" from the DIRECTORIES menu on the phones?
We don't use intercom here (CM 5.2) and the Intercom History entry on the menu just takes up space - users have to scroll down to get to the corporate directory which is all they really want to use.
Thanks!!
Tommer Catlin Fri, 02/08/2008 - 10:50
  • Green, 3000 points or more
You need to upgrade to the newest phone firmware, it will let you remove the Intercom history from the phone.
Rob Huffman Sat, 02/09/2008 - 12:43
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey guys,
Here is a little further info;
CSCsk99117 Bug Details
Intercom History in Directory List when not needed
Symptom:
Intercom History available as an option in Directory when Intercom is not
provisioned for that particular phone, and when in versions of CallManager
prior to 6.
Conditions:
Phone Load 8.3(2) has been installed for 7941/61
Further Information
Intercom History is removed in phone load 8.3.3es3 and later. Contact TAC to
receive an engineering special version with this fix. Intercom History will
also be removed in the upcoming 8.3.4 release which will post to Cisco.com
Fixed-In
8.3(3.11)
8.3(3)ES3
8.4(0.36)
8.3(4.3)
Hope this helps!
Rob
