2 e1 controller cards back to back
Feb 5th, 2008
Hi all, is it possible for me to plug my 2 routers in back to back via the e1 card in it, and how to I configure all 1-32 timeslots to make use of the full 2 mega bandwidth ?
graemeporter Tue, 02/05/2008 - 05:55
Hi Carl,
Yes, you can do it - best bet is to use an RJ-48 crossover cable. Connecting the two back-to-back like this should at least bring up the Carrier Detect light.
As for the next bit - I've only ever done this for an E1 used for voice connecting to a circuit to the PSTN, not for data at all, so excuse any mistakes I make. If anyone spots anything wrong, please let me know as I'd love to learn too!
If it's a dual-purpose E1/T1 WIC you're using, you'll need to specify what mode it should operate in. Use the "card type" command to specify E1 mode for your card (assuming it's port 0 on the E1 card in WIC slot 0):
router(config)# card type e1 0 0
Once that's done, you should be able to set the number of timeslots to use:
router(config)# controller E1 0/0/0
router(config-controller)# pri-group timeslots 1-31
router(config-controllet)# end
router#
At this point, the router should create interfaces for all your timeslots. You will need to do this on both your routers.
You should then be able to set IP addresses on the E1 interfaces, on the signalling channel:
router(config)# interface serial 0/0/0:15
router(config-if)# ip address 10.0.0.1 255.255.255.252
router(config-if)# no shutdown
Obviously, on the other router, you would set 10.0.0.2 255.255.255.252.
From here, I draw a complete blank. If you can PING across between the two 10.x.x.x IP addresses, great. If not, hopefully someone more experienced than me can help you out.
Hope this is at least a good starting point for you.
Kind regards,
Graeme
carl_townshend Tue, 02/05/2008 - 06:55
Hi Graeme
Do you need to use the rj48 crossover cable here ? cant you use an rj45 ?
cheers
Carl
rgodden Tue, 02/05/2008 - 07:26
As they say on Blue Peter, here is two i made up earlier, UTP will work over a short distance as long as the pin outs are correct
carl_townshend Tue, 02/05/2008 - 23:30
what do you mean by pin outs are correct? so can I use a normal car 5 cable, say 2 meters ?
carl_townshend Mon, 02/11/2008 - 05:26
I have used a normal rj45 cable to connect the routers back to back, but im getting this, any ideas ?
E1 0 is down.
Applique type is Channelized E1 - balanced
Far End Block Errors Detected
Receiver has loss of signal.
alarm-trigger is not set
Version info Firmware: 20020306, FPGA: 11
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (72 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 72 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 72 Unavail Secs
rgodden Mon, 02/11/2008 - 05:47
what are the pin outs of the cable, what pins have you crossed to get an e1 crossover cable, do a search for e1 crossover on cisco will give you the answer
microtel Tue, 02/12/2008 - 03:46
Hi Carl,
Did you resolve your problem ..i have the same
Any informations about E1 Crossover??
