Web management on 2950
Feb 5th, 2008
I have cisco 2950 - WS-C2950-24 with IOS c2950-i6k2l2q4-mz.121-22.EA10a.bin
I have disabled incoming telnet connections on switch, and enabled ssh, which is working fine for managing the device.
Now there is a requirement to have web management enabled, and it works only when i allow telnet connection on the switch.
Is it possible to have both ssh and http access enabled on the switch, if yes then how ??
Thanks for your help.
mumbai_datacoms Tue, 02/05/2008 - 05:36
Hi Michael,
Thanks for your reply.
So does that mean I cant have ssh and web management enabled on switches at the same time ??
If yes, then what a dissapointment.
