Image for AIP-SSM
Feb 5th, 2008
I have downloaded:
But managed to install only second one.
For fist one it said that it was a wrong image.
Has anybody know why?
Overall Rating: 4.3 (4 ratings)
andrew.burns Tue, 02/05/2008 - 05:45
It depends what you're trying to do. A ".pkg" file is a normal software upgrade package, whereas a ".img" is a system recovery image file. You'd use the first one if you were doing a normal software upgrade, but the second usually only gets used if you want to wipe the system and start from scratch.
Leo_Stobbe Wed, 02/06/2008 - 02:31
Thanks for reply.
What do you mean " normal software update" ?
What SYS image does/includes?
andrew.burns Wed, 02/06/2008 - 02:59
It's probably best illustrated by example:
Say you buy an ASA with an IPS module already installed with version 6.0. OK, everything is working fine but you notice that software version 6.1 has been released. To upgrade to 6.1 all you need to do is install the upgrade (the "pkg" file). This gives you the new version and keeps all your settings, etc, intact.
Normally, that's all there is to it, but if you have something really bad happen (typically a hard disk failure or something like that) then after the new disk has been installed you'll need the image file (the "img" file). This will format the hard disk, and install both the OS and whatever software version is in the image. You'll then have to restore all your settings from scratch.
It's similar to the difference between installing a windows service pack and reinstalling the whole OS from the CD.
Leo_Stobbe Fri, 02/08/2008 - 00:16
Hi. Thanks for detailed info.
So why AIP-SSM didn't allowed me to install .img file? Or it can be happen only from rommon mode?
AS i understood we can reimage whole Sensor if we connected by console?
Then how we can apply .img file to AIP-SSM? (AIP-SSM doesn't have any console port)
