2 VPN Tunnels on a single Pix Firewall
Feb 5th, 2008
I cureently have a site to site VPN tunnel (VPN1) between HK (Pix ver 6.1(2) & Leeds (ASA version 7.2(2). I am in the process of migrating the VPN tunnel to a newly deployed 10 Mb internet link in Leeds which has a Pix 506E Ver 7.0(2). I have decided to create a 2nd VPN tunnel to HK (VPN2) and will shutdown VPN1 when VPN2 is up.
On the HK PIX I am using the same isakmp policy, transform-set and have created another crypto map for the the new VPN (VPN2).
On passing intersting traffic to establish the new tunnel for the Leeds end, I am gettting the following debugging errors.
Feb 04 15:06:42 [IKEv1]: QM FSM error (P2 struct &0x1b24150, mess id 0x47595d7)!
Feb 04 15:06:42 [IKEv1]: Group = 192.168.0.1, IP = 192.168.0.1, Removing peer from correlator table failed, no match!
Feb 04 15:06:42 [IKEv1]: QM FSM error (P2 struct &0x1b24860, mess id 0x9cafcd4d)!
sh Feb 04 15:06:47 [IKEv1]: QM FSM error (P2 struct &0x1d085d0, mess id 0x458d4091)!
Feb 04 15:06:47 [IKEv1]: Group = 192.168.0.1, IP = 192.168.0.1, Removing peer from correlator table failed, no match!
sh crypto isakmp sa
Active SA: 1
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: 192.168.0.1
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
Site HK - PIX1(192.168.0.1)
crypto ipsec transform-set chevvie esp-des esp-md5-hmac
(crypto map for existing VPN (VPN1)
crypto map transam 1 ipsec-isakmp
crypto map transam 1 match address 101
crypto map transam 1 set peer 192.168.0.2
crypto map transam 1 set transform-set chevvie
(New Crpto Map for new VPN (VPN2)
crypto map transam 2 ipsec-isakmp
crypto map transam 2 match address 101
crypto map transam 2 set peer 192.168.0.3
crypto map transam 2 set transform-set chevvie
crypto map transam interface outside
isakmp enable outside
isakmp key ****** address 192.168.0.2 netmask 255.255.255.255
isakmp key ev0lut10n address 192.168.0.3 netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 1000
isakmp am-disable
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
Site - Leeds PIX2 (192.168.0.3)
crypto ipsec transform-set ford esp-des esp-md5-hmac
crypto map VPNHK 2 match address outside_crypto_acl
crypto map VPNHK 2 set peer 192.168.0.1
crypto map VPNHK 2 set transform-set ford
crypto map VPNHK interface outside
isakmp am-disable
tunnel-group 192.168.0.1 type ipsec-l2l
tunnel-group 192.168.0.1 ipsec-attributes
pre-shared-key ev0lut10n
Your assistance will be grately appreciated.
dasgill Wed, 02/06/2008 - 05:08
The preshared key is fine. I have changed it but the error persists.
husycisco Wed, 02/06/2008 - 07:08
  • Gold, 750 points or more
Hi Donald
Try changing the PSK in above lines as 1 and try again
dasgill Wed, 02/06/2008 - 09:52
PSK passwords set to the same. No joy. Same error message.
husycisco Wed, 02/06/2008 - 11:13
In this case, I suggest upgrading PIX IOS 6.1(2) to 6.3(5)
Also your match-acl for tunnel 192.168.0.2 and 192.168.0.3 are the same (101). Use different match acls for different tunnels
pavlosd Tue, 02/19/2008 - 21:49
If I understand correctly, you new VPN tunnel, "protects" exactly the same traffic (same access-list). How if your firewall going to know which crypto map to follow? [i guess if they are the same it will use the map number.
Have tried to add to crypto map peers under the same crypto map and see if it works?
crypto map transam 1 set peer 192.168.0.3
