CME query
Feb 5th, 2008
Suppose we have 3 different sites - New York, Boston & Chicago. Assuming we have one CME router in Boston, is it possible for phones located at NY & Chicago to connect to Boston CME ?
Overall Rating: 3.3 (3 ratings)
Paolo Bevilacqua Tue, 02/05/2008 - 06:12
Yes, absolutely. You can use either G.729 or G.711 codecs, the choice will depend by your network specifics.
UCBNOCWAN Tue, 02/05/2008 - 23:50
Hi Paolo,
I am afraid that I was not very specific in my query.
My real query is - is it possible for 3 different sites to connect to one CME? The architecture should be something like this - there is a centralized CME router in site A, site B & site C connect over WAN with no CME routers of their own. I don't think it's possible, I mean the CCM model is not applicable here.
Thanks for your kind reply though.
Paolo Bevilacqua Wed, 02/06/2008 - 01:08
Yes, absolutely possible. If you study the the SRND link posted by Rob, you will become a master in designing CMEs for that and more purposes.
UCBNOCWAN Wed, 02/06/2008 - 02:19
Paolo,
I have been through that & it talks about a multisite model with Distributed Call Processing. ( basically each & every site have been their own CME)
I was enquiring about the feasibilty of a multi-site Centralized Call Processing model. ( more than one site connecting to a centralized CME).
UCBNOCWAN Wed, 02/06/2008 - 06:21
Rob,
Hope you are doing good. Thanks for the wonderful SRND.
Have a nice day.
Abhijit.
