Installation Hang-Up VPN 5
A professor at UC Santa Barbara, I downloaded the VPN client, V5, yesterday and tried to install it on Windows XP. It started to install, signaled only 3 seconds left, then hung up and wouldn't finish for several minutes. There was no error message, just an unfinished install. I tried to download again, but this time no install window appeared. I checked the add/remove tool in windows control panel, and no Cisco VPN was indicated; yet the programs in Start showed Cisco icons. I clicked on them, was informed that they would only work with installation. On my harddrive, there is a Cisco folder, with sub-folders.
What should I do? I can't remove the program by means of the control panel, but am reluctant to delete the Cisco folder on the harddrive in case it has already configured with other programs?
Here, by the way, is the URL of the UCSB library page VPN:
I would appreciate any clear, non-technical advice about this problem.
Thank you,
Michael Gordon
