Callmanager Display via Web
Feb 5th, 2008
Hello I'm experiencing problem accessing the CallManager over the Web. I can log into the CallManager over the Web but can't display anything once inside. I can click on something but it will not display the object whats wrong. I having this problem on both of my CMSUBS
Tommer Catlin Tue, 02/05/2008 - 10:47
  • Green, 3000 points or more
Couple things to try:
- If you are on Windows, try it from the Console on the server.
- If you are using your machine, try it from a different machine.
- If it is windows, and you can manage from the console, you may have to restart the CUCM servers. (but since you cant login on either machine or having trouble, I would say it is your browser on your local computer
david.macias Tue, 02/05/2008 - 11:11
  • Blue, 1500 points or more
Try to reinstall Java on your machine and see if that solves anything.
david
