Why cant I ping to different intereface when route is there
Feb 5th, 2008
All our devices are on vlan 1 in one building. However, we are trying to implemenet a new link. All devices
are using the 192.168.1.0 Network. However we are trying to add 192.168.21.0
On our 2950 switch we have 3 routers attached
Users have are given 2 default gateways via DHCP-One Gateway From Router A and the other from Router B
Router A-192.168.1.252
Router B-192.168.1.245
Router C will be the new subnet and Gateway -192.168.21.236
From Router B I can ping the 192.168.21.236 interface.
RouterB#sh ip route 192.168.21.236
Routing entry for 192.168.0.0/16, supernet
Known via "static", distance 1, metric 0
But from router A I cant
router A>sh ip route 192.168.21.236
% Network not in table
From my desktop on the 192.168.1.X subnet, I can ping the 192.168.21.236 interface. Perhaps I using Router B gateway when I do this??
However, when I switch over to the 192.168.21.X subnet, and use the .21.236 on router C-as my default gateway I CAN'T ping Router A but can Ping router B
BUT I have a route to the entire 192.168.1.0 network...via connection to router B. This would include a route to router A
Router C #sh ip route 192.168.1.252
Routing entry for 192.168.1.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via ospf 100
RouterC #ping 192.168.1.252
Sending 5, 100-byte ICMP Echos to 192.168.1.252, timeout is 2 seconds:
Success rate is 0 percent (0/3)
RouterC#ping 192.168.1.245
Sending 5, 100-byte ICMP Echos to 192.168.1.245, timeout is 2 seconds:
However, only when I log into router B-can I ping router A
One thing I failed to mentioni is that Router C has a Primary and Secondary interface.
On Router A-the secondary is pingable but the primary is not-it is also showing connected even though there is a switch between them
RouterA#sh ip route 192.168.1.236
Redistributing via eigrp 1
Routing Descriptor Blocks:
* directly connected, via FastEthernet0/0
I'm stumped
I see no access lists applied to any interface on Router A that would deny ICMP
Edison Ortiz Tue, 02/05/2008 - 11:24
  • Hall of Fame,
    Founding Member
Router B has a static route to Router C as shown here:
Add the same static route on Router A.
HTH,
__
Edison.
nygenxny123 Tue, 02/05/2008 - 18:43
Hi Edison,
Since I can ping the secondary interface on Router C from Router A. Shouldint I also
be able to ping the primary interface on Router C from Router A?
router c
secondary 192.168.1.236
primary 192.168.21.236
Edison Ortiz Tue, 02/05/2008 - 21:04
  • Hall of Fame,
    Founding Member
The secondary IP is on the same subnet as the primary IP on Router A, no need for routing.
On Router A, do the following:
ip route 192.168.21.0 255.255.255.0 192.168.1.236
HTH,
__
Edison.
nygenxny123 Wed, 02/06/2008 - 06:08
Here is the sh ip route to the primary ip interface
RouterA#sh ip route 192.168.21.0
Here is the secondary IP
Router A#sh ip route 192.168.1.236
Route metric is 0, traffic share count is 1
the default route for router A actually goes to our ISP.
