More SMTP errors after installing new ASA
Feb 5th, 2008
I installed a new ASA5510 in place of our old PIX515E last Thursday night. Since then, our GroupWise server has been showing a significantly higher level of deferred email. The logs are full of messages similar to the excepts I've pasted below.
We are at a loss and trying to track down the problem. Do you have any thoughts on what might be happening?
- Steve Kadish
02-04-08 21:24:04 0 MSG 32517 Analyzing result file: VCCNW2/GRPWISE:\VCNY_DO\WPGATE\GWIA\result\r7a729cc.049
02-04-08 21:24:04 0 MSG 32517 Detected error on SMTP command
02-04-08 21:24:04 0 MSG 32517 Command: aol.com
02-04-08 21:24:04 0 MSG 32517 Response: 450 Host down (aol.com)
02-04-08 21:24:04 0 MSG 32518 Analyzing result file: VCCNW2/GRPWISE:\VCNY_DO\WPGATE\GWIA\result\r7a734a1.018
02-04-08 21:24:04 0 MSG 32518 Detected error on SMTP command
02-04-08 21:24:04 0 MSG 32518 Command: millerscott.com
02-04-08 21:24:04 0 MSG 32518 Response: 421 secure00.secure-transact.net: SMTP command timeout - closing connection
02-04-08 21:42:42 6 DMN: MSG 32591 Send Failure: 421 calmail.berkeley.edu: SMTP command timeout - closing connection
02-04-08 21:56:22 7 DMN: MSG 32624 Send Failure: 450 Host down (hvc.rr.com)
02-04-08 21:57:11 33 DMN: MSG 32707 Send Failure: 421 Exceeded allowable connection time, disconnecting.
rstevek Tue, 02/05/2008 - 09:31
Hi all,
I found the information below in a Cisco.com knowledgebase article. Turning off inspect for ESMTP solved our problem; as soon as it was off, our mail server started sending and receiving the deferred mail. However, I'm not sure what the consequences of turning off the inspection are; could this introduce some other problems or security holes?
- Steve
SMTP TLS Configuration
Note: If you use Transport Layer Security (TLS) encryption for e-mail communication then the ESMTP inspection feature (enabled by default) in the PIX drops the packets. In order to allow the e-mails with TLS enabled, disable the ESMTP inspection feature as this output shows.
pix(config)#policy-map global_policy
pix(config-pmap)#class inspection_default
pix(config-pmap-c)#no inspect esmtp
pix(config-pmap-c)#exit
pix(config-pmap)#exit
markisaac Tue, 07/01/2008 - 12:47
Steve,
Thank you for posting this. This resolved my issue with TLS.
