multi(link) Frame Relay and QoS
Feb 5th, 2008
I wanted to know better way to bundle/balance multiple frame Relay t1s.
I am using IP CEF for now and here is my config:
ip cef
interface Serial0/0
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial0/0.1 multipoint
bandwidth 768
ip address 192.168.172.54 255.255.255.252
ip load-sharing per-packet
traffic-shape rate 768000 768000 768000 1000
traffic-shape fecn-adapt
frame-relay map ip 192.168.172.53 100 broadcast
interface Serial1/0
interface Serial1/0.1 multipoint
bandwidth 768
ip address 192.168.172.58 255.255.255.252
frame-relay map ip 192.168.172.57 101 broadcast
It woks fine. But I wanted to do simple qos on top of it and I am not sure about how. Anyway, here is what I would like to try:
class-map match-all TEST
match access-group 111
policy-map IP-POLICY
class TEST
bandwidth percent 70
class class-default
fair-queue
policy-map BANDWIDTH-POLICY
class class-default
shape average 768000
service-policy IP-POLICY
But I am not sure I can apply this on both frame interfaces.
Please help me.
Thanks!
Edison Ortiz Tue, 02/05/2008 - 11:01
  • Hall of Fame,
    Founding Member
You did all the hard work :)
Remove the traffic shape commands from the serial interfaces and just apply service-policy output BANDWIDTH-POLICY
You can verify the command is applied with show policy-map interface
HTH,
__
Edison.
