Private VLAN between Cisco switch and other vendor switch or firewall
Feb 5th, 2008
Can anyone plz help me in understanding the tagging of private vlan on trunk ports.
I have a trunk link between nokia firewall and cisco 3750 switch, there are some servers in private vlan in the switch and need to communicate to a server behind the firewall, can just a trunk link between the firewall and the switch suffice (consider the firewall in not blocking any traffic)
aghaznavi Mon, 02/11/2008 - 08:02
  • Silver, 250 points or more
Most non-Cisco 802.1q switches maintain only a single instance of spanning tree, known as Mono Spanning Tree (MST), that defines the spanning-tree topology for all VLANs. When a Cisco switch is connected to a non-Cisco switch through an 802.1q trunk, the MST of the non-Cisco switch and the native VLAN spanning tree of the Cisco switch combine in order to form a single spanning tree topology, known as the Common Spanning Tree (CST).
tmsundar81 Mon, 02/11/2008 - 08:38
Thanks for the info but i need to understand the tagging between a cisco switch and a non cisco switch...say i have a private vlan on a cisco switch and i am connecting to a non cisco switch (nokia fw) and i ahave a trunk link between (only trunk link)between then..in such case can a reach the private vlan from nokia fw via the trunk link
or do i need to have a seperate link for the private vlan between cisco switch and nokia fw (promiscuous port on cisco switch end)
