1242AG when reboot stops broadcasting SSID's?
Need some advice, I have 2 SSID's set on the dot11radio0 interface each on a seperate vlan with mbssid set. All works fine. I can associate ok to either and vlan trunking is working. Whenever I power down the AP for any period of time and restart, the SSID's no longer broadcast. All interfaces are up up.
Any advice is appreciated
IOS C1240-K9W7-MX.124-10B.JA
dot11 ssid avnet
vlan 1
authentication open
dot11 ssid homenet
vlan 2
authentication open
mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 key 1 size 128bit 7 256C360B1CD135784F0448257840 transmit-key
encryption vlan 2 key 2 size 128bit 7 FD4A6BD63DE57FD26B5F05382FE2
encryption vlan 2 key 3 size 128bit 7 1C394A6BD63DE57FD26B5F05382F
encryption vlan 2 key 4 size 128bit 7 904B7305171C22031220D71D6339
encryption vlan 2 mode wep mandatory
encryption vlan 1 key 1 size 128bit 7 624CE1586C360B1CD135784F0448 transmit-key
encryption vlan 1 key 2 size 128bit 7 0E4825784036242F11302113E42E
encryption vlan 1 key 3 size 128bit 7 4F25784036242F11302113E42E50
encryption vlan 1 key 4 size 128bit 7 1D7958E50ED64CE1586C360B1CD1
encryption vlan 1 mode wep mandatory
ssid avnet
ssid homenet
mbssid
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 192.168.0.3 255.255.255.0
no ip route-cache
Rob Huffman Tue, 02/05/2008 - 13:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Julian,
Unless I am missing something (no surprise:). It looks like only "homenet" is set to Broadcast using the "guest-mode" command;
dot11 ssid homenet
vlan 2
authentication open
mbssid guest-mode
This one "avnet" is not set to Broadcast;
dot11 ssid avnet
vlan 1
authentication open
Hope this helps!
Rob
Rob,
Thanks for your input. You are correct that I only want to guest broadcast the homenet SSID. The strange thing is that with using Netstumbler when I first build the AP config I can see both SSID's and connect to both without issue. When I have the AP sit unpowered for a couple of hours and power back on, it doesn't respond to association attempts anymore. I then have to default it and rebuild.
Rob Huffman Wed, 02/06/2008 - 06:26
  • Hall of Fame,
    Founding Member
Hi Julian,
That is very strange indeed! What IOS are you running? Are you remembering to Write your config changes?
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
