Faxing issues on VG224
Feb 5th, 2008
I have about 15 different fax machines connected to a VG224 (various models). For some reason only the Brother 3800 models can not send (but they can receive).
The VG224 is configured with MGCP and the PSTN gateway is running H323. I've tried setting the fax rate in the MGCP config and pass-though on the H323 config. Does anyone have any other suggestions? Here are the configs.
************************VG224
voice-port range 2/0 - 23
alt-battery-feed feed2
ccm-manager redundant-host 10.10.10.1
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.10.1
ccm-manager config
ccm-manager config dialpeer-prefix
mgcp
mgcp call-agent 10.10.10.2 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 9600
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
dial-peer voice 99920 pots
service mgcpapp
port range 2/0 - 23
********************PRI Gateway
voice service voip
fax protocol pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
h225 timeout tcp establish 2
dial-peer voice 1 pots
description **** PRI T1
destination-pattern 9T
fax rate disable
port 0/0/0:23
dial-peer voice 10 pots
description **** CAS T1
preference 1
fax rate disable
port 0/1/0:1
dial-peer voice 1001 voip
description **** Call Manager 2
destination-pattern [1-9]...
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.2
incoming called-number .
dtmf-relay h245-alphanumeric
fax rate disable
no vad
dial-peer voice 1002 voip
description **** Call Manager 1
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.10.1
fax rate disable
no vad
hadbou Mon, 02/11/2008 - 08:03
Paste the following config:
1) show tech
2) debug voice ccapi inout ( for failed fax calls)
I have had zero luck getting the VG224 to work in both directions with MGCP.
We had MGCP on out PRi coming in and MGCP on the Vg224 setup with fax passthrough. We were able to fax out, at least from our test fax.
After spending a week with Cisco TAC and not gettting anywhere, I then converted the PRI gateway to H323 fax pass through. We were able to fax in, but not out.
I only had success by converting both to H.323.
Of course now mt ATAs will not work.
pcameron Tue, 02/12/2008 - 03:29
We see a lot of issues on later model faxes defaulting to a mode called SuperG3, which uses some T30 fax signaling modes, V8 modem call control signaling and V34bis modem tones to pass fax traffic at 33.6Kbps. It tends to mess up T38 fax relay for starters (on all brands of gear ... not just Cisco!).
Often the best thing is to go into config mode on the fax and find the config settings for "ECM - Error Correction Mode" and/or "V34/SuperG3 mode" and set them both to OFF. These have the effect of forcing the fax to go back to 'normal' T30 fax mode, which interoperates with the majority of fax machines.
Might be worth giving this a try on the Brother fax machine.
