02-05-2008 09:40 AM - edited 03-18-2019 08:25 PM
We have a VG224 that after so many days it stops with dial tone to all of my fax machines.
Here is the version
ROM: System Bootstrap, Version 12.3(7r)T2, RELEASE SOFTWARE (fc1)
rcw-vg224-1 uptime is 15 minutes
System restarted at 17:24:28 UTC Tue Feb 5 2008
System image file is "slot0:vg224-i6s-mz.124-12.bin"
Cisco VG224 (R527x) processor (revision 4.1) with 119808K/11264K bytes of memory.
Processor board ID FHK1023F09S
R527x CPU at 225MHz, Implementation 40, Rev 3.1
1 On-Board Twenty-Four FXS Analog Voice Module V2.1
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
63K bytes of non-volatile configuration memory.
System fpga version is 250027
System readonly fpga version is 250025
Option for system fpga is 'system'.
62720K bytes of ATA Slot0 CompactFlash (Read/Write)
The only soultion I have to fix the problem is to reboot the vg224.
Any ideas?
02-11-2008 10:51 AM
Just check the status of the ses debugs:show voice call sum and show voice port sum. You can upgrade the software in vg224.
02-11-2008 11:16 AM
Can you pls give the show config for VG ?
Thanks..Tulsi Ram
02-11-2008 11:22 AM
version 12.4
no service pad
service password-encryption
hostname rcw-vg224-1
boot-start-marker
boot system flash slot0:vg224-i6s-mz.124-12.bin
boot-end-marker
no aaa new-model
ip cef
stcapp ccm-group 1
stcapp
voice-card 0
class-map match-any voice
match any
policy-map voice
class voice
set dscp ef
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
voice-port 2/0
caller-id enable
voice-port 2/1
caller-id enable
voice-port 2/2
caller-id enable
voice-port 2/3
caller-id enable
voice-port 2/4
caller-id enable
voice-port 2/5
caller-id enable
voice-port 2/6
caller-id enable
voice-port 2/7
caller-id enable
voice-port 2/8
caller-id enable
voice-port 2/9
caller-id enable
voice-port 2/10
caller-id enable
voice-port 2/11
caller-id enable
voice-port 2/12
caller-id enable
voice-port 2/13
caller-id enable
voice-port 2/14
caller-id enable
voice-port 2/15
caller-id enable
voice-port 2/16
caller-id enable
voice-port 2/17
caller-id enable
voice-port 2/18
caller-id enable
voice-port 2/19
caller-id enable
voice-port 2/20
caller-id enable
voice-port 2/21
caller-id enable
voice-port 2/22
station-id number 3202226937
caller-id enable
voice-port 2/23
station-id number 3202226938
caller-id enable
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
no mgcp fax t38 ecm
sccp local FastEthernet0/0
sccp ccm ? identifier 2
sccp ccm ? identifier 1
sccp
sccp ccm group 1
description SHOT CallManagers
associate ccm 2 priority 2
associate ccm 1 priority 1
signaling dscp af31
dial-peer voice 100 pots
service stcapp
port 2/0
dial-peer voice 101 pots
service stcapp
port 2/1
dial-peer voice 102 pots
service stcapp
port 2/2
dial-peer voice 103 pots
service stcapp
port 2/3
dial-peer voice 104 pots
service stcapp
port 2/4
dial-peer voice 105 pots
service stcapp
port 2/5
dial-peer voice 106 pots
service stcapp
port 2/6
dial-peer voice 107 pots
service stcapp
port 2/7
dial-peer voice 108 pots
service stcapp
port 2/8
dial-peer voice 109 pots
service stcapp
port 2/9
dial-peer voice 110 pots
service stcapp
port 2/10
dial-peer voice 111 pots
service stcapp
port 2/11
dial-peer voice 112 pots
service stcapp
port 2/12
dial-peer voice 113 pots
service stcapp
port 2/13
dial-peer voice 114 pots
service stcapp
port 2/14
dial-peer voice 115 pots
service stcapp
port 2/15
dial-peer voice 116 pots
service stcapp
port 2/16
dial-peer voice 117 pots
service stcapp
port 2/17
dial-peer voice 118 pots
service stcapp
port 2/18
dial-peer voice 119 pots
service stcapp
port 2/19
dial-peer voice 120 pots
service stcapp
port 2/20
dial-peer voice 121 pots
service stcapp
port 2/21
dial-peer voice 122 pots
port 2/22
dial-peer voice 123 pots
port 2/23
dial-peer voice 6938 pots
destination-pattern 6938
port 2/23
05-15-2008 03:07 PM
Did you get any response? I am having a similar problem. I have no dial tone after few days.
Thanks and best regards
05-16-2008 04:47 AM
No I did not. I am still experiencing the problem. Only way to fix is to reboot. My customers are not happy.
05-16-2008 04:57 AM
I have a TAC case and they said that it is may be a hardware problem.
Did you change the hardware?
What version of IOS? I have 12.4.19.
We are about to go in service by Monday so I will face unhappy customer as well.
Thanks and regards
05-16-2008 05:00 AM
No I did ot change out the hardware. I have two VG224's and tried the connection on both with the same result.
We are currently running (vg224-I6S-M), Version 12.4(12). I cannot upgrade because when I do, everything connected to the switch will not work. The devices hear a low hum that eventually gets louder.
05-16-2008 10:31 AM
Hi Neil,
If the "low hum that eventually gets louder" you hear is in the 50-60Hz range, you may have a "ground loop" issue -- that is, your fax machine is grounded at a different point in your electrical system than your voice gateways.
To isolate your issue, can you take a fax machine to the same room the voice gateway is physically located in? If the fax is connected to the same ground that the VG is, and the hum disappears, that may be your culprit.
Alternatively, you may be encountering electromagnetic interference (EMI) on the cable connecting your gateways to your fax machines. Make sure that there aren't any ballasts (noisy ballasts are common in older fluorescent lights) in close proximity to the wire (or any other electrical equipment that could cause interference for that matter).
If EMI is the culprit it's harder to diagnose. You might need to move your fax machines to a different drop point to eliminate the issue.
Hope that helps!
-James.
05-16-2008 11:25 AM
Anyway to enter the vg224 into a debug mode on a single port so that I could tell what is going on?
05-19-2008 12:09 PM
Experienced recently the same issue.
What i did:
-> ios upgrade to latest version, reconfigure everything (gw and ccm), reboot, reset gw, and the problem still revealed, some analog phones worked, some not.
What aparently resolved:
-> vg224 was connected to UPS. After connecting directly to public power the issue STOPED. Reconnected to UPS and its working.
What do you have to say? I dont have words.
Met.
05-19-2008 12:34 PM
Which problem did you fix by unplugging the
UPS (hum or dial-tone)?
I am having the Dial-tone problem.
Thanks and regards
05-19-2008 12:35 PM
dial-tone, my only problem.
Regards.
05-29-2008 06:33 AM
Is there any way to set the vg224 to debug mode on a port? There are many options but I am unsure which to use.
Maybe send the output to a syslogbox
05-29-2008 06:41 AM
For your information:
My problem is fixed with version:
vg224 Software (vg224-I6S-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
