Two PIX525 Configuration with Different OS ver
Feb 5th, 2008
Can someone help my follwing problem:
I have two PIX525, one is in production (Version 6.2(1)) and one is standby (Version 6.3(5)). Both PIX525 are UR license with the same configuration. The plan is if the production PIX525 was failed, we can switch the network to the standby PIX525. The standby PIX525 does not connect to the network when the production PIX525 is running. (This is not Failover connection.)
When I tested the standby PIX525 in the production environment, it was failed. During this test, I could ping the IP address of inside and outside interface. But the port 80 traffic could not pass through the standby PIX525. I also noticed that there was an error in the syslog during the test:
"(Secondary) Failover cable not connected (this unit)"
I am not sure why it came out the above error message during the test. The Failover is disabled and no failover cable is connected to the standby PIX525.
When the standby PXI525 was replaced by the production PIX525 (connected back to the same network), everything worked fine.
Here is the “sh run” of production PIX525 (working PIX):
PIX525# sh run
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname PIX525
domain-name ciscopix.com
fixup protocol http 80
fixup protocol http 443
names
access-list acl_out permit tcp any host x.x.x.x eq www
access-list acl_out permit tcp any host x.x.x.x eq https
pager lines 24
interface ethernet0 100full
interface ethernet1 100full
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.254.0
ip address inside x.x.x.x 255.255.0.0
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address intf2 0.0.0.0
failover ip address intf3 0.0.0.0
pdm history enable
arp timeout 14400
global (outside) 1 x.x.x.x-x.x.x.x netmask 255.255.254.0
global (outside) 1 x.x.x.x netmask 255.255.254.0
nat (inside) 1 x.x.x.x 255.255.0.0 0 0
static (inside,outside) x.x.x.x x.x.x.x netmask 255.255.255.255 0 0
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
no sysopt route dnat
Here is the “sh run” of standby PIX525 (not working):
PIX525# sh run
PIX Version 6.3(5)
enable password iV.bykN9za7xaE.x encrypted
passwd iV.bykN9za7xaE.x encrypted
hostname PIX525
names
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
failover poll 15
no failover ip address outside
no failover ip address inside
pdm history enable
arp timeout 14400
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
Thanks. -Simon
srue Tue, 02/05/2008 - 10:05
  • Blue, 1500 points or more
how long did you leave the standby 525 in place before calling it quits since it wasn't working properly?
There may have been some arp cache problems on any/all devices connected to it.
clear the arp cache on any attached devices/hosts you have problems with next time you try this.
Basically, surrounding devices have a different MAC for the firewall's IP so it needs to be cleared on all the other devices...or just let it time out naturally.
simonli007 Tue, 02/05/2008 - 14:29
I rebooted all the switches on the network after connecting the standby PIX525 to the production environment. I believe it would clear all the arp cache. I was also able to ping both inside and outside IP during the test. But when I browsed the website either from inside to outside or from outside to inside, neither will work. The syslog server received a error message during the test:
I am not sure why standby PIX525 generated the above error message. Is it possible that the standby PIX525 did not work is because the above error message? But I don't know how to get rid of the above error message.
Thank you very much for your reply.
srue Tue, 02/05/2008 - 15:37
you need to check the license on the 525 and make sure it's not a failover license.
simonli007 Tue, 02/05/2008 - 15:42
The "sh ver" shows it is UR license.
Thanks again for your reply.
simonli007 Tue, 02/05/2008 - 16:18
I also noticed the difference between the production PIX525 and stnadby PIX525 regarding the failover configuration:
Production PIX525:
no failover
failover poll 15
Standby PIX525:
no failover
failover poll 15
Will it cause any problem on standby PIX525?
Is there any other possibility to cause the error message in syslog?
Thanks.
johnd2310 Tue, 02/05/2008 - 16:48
  • Silver, 250 points or more
Has the standby pix been rebooted also?
John
simonli007 Tue, 02/05/2008 - 17:10
yes, all switches and standby PIX525 were rebooted during the test in production environment. But it still did not work.
Any other thought that could cause this weird problem?
Thanks for your reply
sivakondalarao Wed, 02/06/2008 - 01:42
I suggest you to simulate the setup as minimal as possible to troubleshoot this issue with standby pix.
regards
skrao
simonli007 Wed, 02/06/2008 - 09:19
Thanks for your suggestion.
I am very curious why the standby PIX525 is UR license and failover is disabled but it generates the following message in the syslog server during the test:
I suspect this is the problem caused the standby PIX525 did not work. Can anyone help to answer my question.
Thanks.
Simon
