Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929544members
1244150discussions
Community Activity
ISE CoA Reauth for Aruba 2530
Hello everyone, Does anyone know the attributes to configure to make the CoA type reauth work on an Aruba 2530 switch (16.11)? I managed to make the CoA Disconnect and port bounce working but I don't have the solution for reauth and I need it for pro...
Cisco Table Microphone Pro LAN connection?
I've went through the available documentation of the new Cisco Table Microphone Pro but I could not find if the microphone UTP/LAN cable can be connected to the same LAN of the Room codec or if it needs to be connected to the private LAN of the codec...
gfolens by Level 4
  • 64 Views
  • 2 replies
How Do I Connect With People on 𝗔𝗶𝗿 𝗖𝗮𝗻𝗮𝗱𝗮? >>UrgentCalls
Talk to someone on 헔헶헿 헖헮헻헮헱헮, you have a few options. You can give them a call at their customer service hotline, which is ퟭ-(ퟴퟬퟱ) ퟯퟬퟵ-ퟵퟯퟳퟳ orퟏ-(ퟖퟎퟓ) ퟑퟎퟗ ퟗퟑퟕퟕ (퓛퓲퓿퓮 퓟퓮퓻퓼퓸퓷). Alternatively, you can chat with them live on their website or utilize thei...
Catalyst center backups
HiCan I jusy clarify some backup information please?  The automation only backup is what you would restore if your cluster went awol and you are recovering all your fabric info?  Device configs, hand offs, port allocations, L2/L3 VN info, SGT matrix ...
KevinR99 by Level 1
  • 0 Views
  • 0 replies
Catalyst 9200/9300/3850/3650 シリーズにおいてスイッチの system-report が生成されない
2024年4月24日 (初版) TAC SR Collection主な問題 Catalyst 9200/9300/3850/3650 シリーズにおいて、ソフトウェアバージョン 16.12.3 を使用しスタックを組んでいる場合、 iosd プロセスによってクラッシュした際に障害解析のための system-report が生成されない可能性があります。クラッシュの際、通常は下記のように crashinfo file や core file などがまとめられて system-report として...
copy xmodem initializing no transfer c2960
Hi Guys, i had this problem for 8 hours now and can't seem to get it cracked... after i input the command copy xmodem: flash:c2960-lanbasek9-mz.152-7.e9.binand using the SecureCRT going to Transfer > send xmodem I get this and after that nothing happ...
ACI multipod with vPC HA FW
Hi All, I need your assistance to check if the following configuration going to work and are there any drawbacks/caveats?So far I identified OSPF convergence time and impact on a relatively large area 0 *(legacy design). Solution details:I have ACI M...
wireless authentication
hello I am working in an environment where there is a wireless guest infrastructure configured  guest users are given access by an Administrator based on their email  there is  a requirement for a wireless printer to be given access to this guest net...
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
Jason2005 by Level 1
  • 249 Views
  • 13 replies
IPSEC VPN
Hello Team,I have below topology : -I have ipsec vpn from on-prem to aws cloud. the two endpoints  [192.168.40.10/32, 192.168.30.10/32] work fine as they are allowed on the encryption domain.I have users using remote vpn to connect to on-prem dc to a...
fmugambi by Spotlight
  • 76 Views
  • 12 replies
Expressway Single Domain 2 Seperate Expressways
Hi,We have a customer using HCS. As part of this we set up Expressway for them during the first lockdown for them to be able to use Jabber remotely for voice only (no IM&P). They use the same domain name internally and externally e.g. abc.com Another...
mikee2112 by Level 1
  • 420 Views
  • 1 replies
Catalyst 9000: NetFlow において Inactive flows がタイムアウトされない
2024年4月23日 (初版) TAC SR Collection主な問題 Catalyst 9000 シリーズの機器において uptime が一年以上になっている場合、 NetFlow においてInactive flows のキャッシュテーブルがタイムアウトされず、残り続ける可能性があります。 原因 この問題は CSCwa64171 として報告されております。 解決策 回避策:再起動によりタイムアウトされます。恒久対策:CSCwa64171 の不具合が修正されているバージョンをご利用くだ...
CISCO WSA upgrade alert error
We have upgraded our S1000v(wsa ) from 14.5.1 to 14.5.2 and upgrade was successful but when we checked the alerts we found an alerts as An application fault occurred: ('heimdall/svc.py send_command|195', "<class 'heimdall.exceptions.unknownprocess'="...
DK9 by Level 1
  • 96 Views
  • 6 replies
