MIB walk for a router with RMON alarmTable populated
Feb 5th, 2008
To perform some testing in an agent I ma building I need a MIB walk for a router with RMON alarmTable populated. Does any one know where I can get one?
Joe Clarke Tue, 02/05/2008 - 10:17
Here's one from one of our lab devices:
RMON-MIB::alarmIndex.10 = INTEGER: 10
RMON-MIB::alarmIndex.999 = INTEGER: 999
RMON-MIB::alarmIndex.13244 = INTEGER: 13244
RMON-MIB::alarmInterval.10 = INTEGER: 60 Seconds
RMON-MIB::alarmInterval.999 = INTEGER: 10 Seconds
RMON-MIB::alarmInterval.13244 = INTEGER: 20 Seconds
RMON-MIB::alarmVariable.10 = OID: RS-232-MIB::rs232Number.0
RMON-MIB::alarmVariable.999 = OID: IF-MIB::ifOperStatus.15
RMON-MIB::alarmVariable.13244 = OID: CISCO-PROCESS-MIB::cpmCPUTotal5sec.1
RMON-MIB::alarmSampleType.10 = INTEGER: absoluteValue(1)
RMON-MIB::alarmSampleType.999 = INTEGER: absoluteValue(1)
RMON-MIB::alarmSampleType.13244 = INTEGER: absoluteValue(1)
RMON-MIB::alarmValue.10 = INTEGER: 0
RMON-MIB::alarmValue.999 = INTEGER: 2
RMON-MIB::alarmValue.13244 = INTEGER: 4
RMON-MIB::alarmStartupAlarm.10 = INTEGER: risingOrFallingAlarm(3)
RMON-MIB::alarmStartupAlarm.999 = INTEGER: risingOrFallingAlarm(3)
RMON-MIB::alarmStartupAlarm.13244 = INTEGER: risingOrFallingAlarm(3)
RMON-MIB::alarmRisingThreshold.10 = INTEGER: 1
RMON-MIB::alarmRisingThreshold.999 = INTEGER: 2
RMON-MIB::alarmRisingThreshold.13244 = INTEGER: 80
RMON-MIB::alarmFallingThreshold.10 = INTEGER: 0
RMON-MIB::alarmFallingThreshold.999 = INTEGER: 1
RMON-MIB::alarmFallingThreshold.13244 = INTEGER: 20
RMON-MIB::alarmRisingEventIndex.10 = INTEGER: 1
RMON-MIB::alarmRisingEventIndex.999 = INTEGER: 999
RMON-MIB::alarmRisingEventIndex.13244 = INTEGER: 1
RMON-MIB::alarmFallingEventIndex.10 = INTEGER: 2
RMON-MIB::alarmFallingEventIndex.999 = INTEGER: 1000
RMON-MIB::alarmFallingEventIndex.13244 = INTEGER: 2
RMON-MIB::alarmOwner.10 = STRING: "config"
RMON-MIB::alarmOwner.999 = STRING: "jclarke"
RMON-MIB::alarmOwner.13244 = STRING: "me"
RMON-MIB::alarmStatus.10 = INTEGER: valid(1)
RMON-MIB::alarmStatus.999 = INTEGER: valid(1)
RMON-MIB::alarmStatus.13244 = INTEGER: valid(1)
aweiss1953 Tue, 02/05/2008 - 11:22
Joe,
Is there a chance I can get an electronic copy of the walk for the whole router? :-)
We use mimic to simulate our devices and actually load the device walks into mimic to test with.
Joe Clarke Tue, 02/05/2008 - 11:53
I can't give you the walk of the entire tree, but here are walks of the IF-MIB, CISCO-PROCESS-MIB, and RS-232-MIB which are referenced in this alarmTable.
