Warning message
Cisco Works DR Solution Design - Active/Active Systems
Feb 5th, 2008
Designing a Cisco Works DR solution with dual active LMS 3.1 systems on seperate subnets. Can Cisco infrastructure devices be configured to send snmp-server trap and syslog messages to both active systems. Is there a Cisco best practice to follow for this type of solution.
Joe Clarke Tue, 02/05/2008 - 11:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, network devices can be configured to send traps and syslog messages to both servers. You just need to configure two "logging X.X.X.X" lines and two "snmp-server host X.X.X.X" lines. The leading practice is to limit the number of trap and syslog destinations to no more than four to prevent overwhelming the device. If you need more than four destinations, you should go with a trap/syslog forwarder application.
For other leading practices, you should check out the LMS whitepapers at http://www.cisco.com/en/US/products/sw/cscowork/ps2425/prod_white_papers_list.html . Of particular interest will be the large scale deployment guide.
