WAE 512 - Kernal Crash Files Detected Error
Answered Question
Feb 5th, 2008
I've just run the WAAS Disk check on my WAE 512 (script execute disk_check.sh) before implementing an upgrade to 4.0.15 from 4.0.13.
After the WAE reboots I get the following major alert on the CM
'Kernal Crash files and / or User Core files detected'
Any ideas on what I need to do, or files I need to complete to fix this.
Many Thanks,
Richard
Correct Answer by Zach Seils about 9 years 3 months ago
Richard,
There should be a crash file located in the following directory:
/local1/core_dir
Grab that file and open a TAC case (or send it to me). You can clear the alarm by deleting the file from the core_dir directory.
Zach
Overall Rating: 5 (3 ratings)
Correct Answer
Zach Seils Wed, 02/06/2008 - 03:35
  • Cisco Employee,
Richard,
/local1/core_dir
Zach
richianaj Wed, 02/06/2008 - 07:37
Thanks - that worked great. File on its way to you.
Zach Seils Fri, 02/08/2008 - 05:31
  • Cisco Employee,
Richard,
Thanks for the file. I can't find any previous occurrences of this type of crash. Since the file was generated under version 4.0.13, it may have been a problem with the way TFO exited as part of the upgrade. I would say that you can ignore this instance unless it happen again under 4.0.15.
Zach
