BLF Question
Feb 5th, 2008
  • Silver, 250 points or more
I have set up an expansion module, 7914, with a 7961 phone.
I build the phone template and needed BLF set-up.
I have 9 BLF on buttons 9-18
However, I do not get the visual indication that someone is on the line. The SD function works just fine but I do not see the inidcator.
Is there something else I am missing?
Anonymous (not verified) Mon, 02/11/2008 - 13:38
You may be hitting with this bug:CSCsg12278
phillips.chris Wed, 03/26/2008 - 11:24
Check the "SUBSCRIBE" calling search space on the device. Make sure that it is set to a CSS that can call the DN's that are on your BLF buttons.
Dany Daoud Thu, 03/27/2008 - 13:20
you need to setup SUBSCRIBE Calling Search Space for the end user under user management.
Rick Morris Thu, 03/27/2008 - 13:21
Sorry all I figured this out shortly after setting this up.
I needed to build a preference group, then assign the group to the device and enable the feature.
Assign the button and everything worked.
Thanks all.
