Multiple IPs on an interface
Feb 5th, 2008
Is there a way to add more than one IP on an interface for an ASA 5510 running V8.0(3) software?
cisco24x7 Tue, 02/05/2008 - 13:25
No you can not do that on ASA/Pix devices,
to my knowledge
If you want to add "secondary" IP addresses
on a security device, go buy a Nokia appliance
running IPSO and it will let you add
secondary ip addresses just like Cisco IOS
CCIE Security
sivakondalarao Wed, 02/06/2008 - 01:55
shall I know your purpose to add more IP addresses to single interface.
robertgile1 Wed, 02/06/2008 - 07:15
The ASA was using another public IP in my netblock for testing purposes. I had a working Site to Site VPN connection and just wanted to add my current production IP to the interface, instead of trying to rebuild that VPN tunnel. I had to have a Cisco support person help me in config since the wizard didn't work at all.
husycisco Wed, 02/06/2008 - 07:23
Hi Robert
You can achieve what you want with the help of a Layer3 switch. If you have one, you can create subinterfaces on ASA, set trunk port on switch, create VLANs and tag them.
robertgile1 Wed, 02/06/2008 - 08:04
But that would require me to have IP addresses on seperate subnets. These public IPs are on the same subnet.
Plus I dont have an L3 switch...wish I did though!
Thanks for the replies guys. If anyone has any more suggestions, I am open.
