02-05-2008 12:32 PM - edited 03-03-2019 08:34 PM
The IOS is gone, command is on the "switch" mode. How do get it back up and running with a new IOS? Thanks.
02-05-2008 12:55 PM
You may need to xmodem the new image,
see
HTH,
__
Edison.
02-05-2008 04:27 PM
Hint:
If you do need to xmodem an image, many of the newer console ports can go much faster than the usual 9600. Very worthwhile to increase console port speed (often will still be painfully slow compared Ethernet).
02-06-2008 04:34 AM
How do you do that? Thanks Joseph.
02-06-2008 04:45 AM
Follow the procedure in this link http://www.cisco.com/warp/public/130/xmodem_generic.html
..the procedure in the link is generic for XMODEM, so ignore those router model mentioned in the link.
Dandy
02-06-2008 05:38 AM
you can also use tftpdnld command in ROMMON mode
