02-05-2008 12:42 PM - edited 03-05-2019 08:57 PM
Interfaces on the same VLAN receive IP multicast's from other streamers on the same VLAN. This doesn't scale well and it is not a proper setup for each streamer to automatically receive one another's multicast.
Problem description detail:
Streamer 1 and 2 are both apart of vlan 967. Streamer 2 receives all multicast streams from streamer 1 without any requests. Conversely, streamer 1 receives all of streamer 2's multicasts! I need to prevent the streamers traffic from hitting one another.
Global:
no ip igmp snooping
ip multicast-routing
Source VLAN with backfeed problem:
interface Vlan967
description Modulus Encoders
ip address 10.1xx.yy.65 255.255.255.0
ip pim sparse-dense-mode (same result with just ip pim)
end
sho ip mrout count | i 239.20.0.2
Group: 239.1.7.2, Source count: 1, Packets forwarded: 1847630873, Packets received: 1847630873
If I remove PIM from the source vlan then the 6500 does not seem to recognize the multicast coming in from the streamers. The mroute doesn't show up but the traffic counters in the Ethernet interface continue to increment:
interface Vlan967
end
sho ip mrout count | i 239.1.7.2
Group: 239.1.7.2, Source count: 0, Packets forwarded: 0, Packets received: 0
It would make sense to have IGMP snooping on for the streamer vlan but the Cisco does not seem to accept the command (after issuing the command it does not show up in the vlan interface configuration).
Other info about the network that is a requirement and working fine with the current setup:
Most of my interfaces require me to send the multicast's without any igmp requests. This is easy to do with the ip igmp static-group command such as in this destination VLAN:
interface Vlan973
description Spare-C7-Network
ip address 10.1xx.zz.65 255.255.255.0
ip pim dense-mode
ip igmp static-group 239.20.0.12
ip igmp static-group 239.10.0.66
ip igmp static-group 239.50.0.78
ip igmp static-group 239.70.3.0
ip igmp static-group 225.73.73.1
ip igmp static-group 226.73.73.2
ip igmp static-group 226.73.73.3
ip igmp static-group 226.73.73.4
Of course I also have periodic testing that requires me to make an IGMP request from another vlan and request multicast streams from the source vlan 967. For instance, if I'm plugged in as a client to a port apart of vlan 943 I can make an IGMP request and pull the multicast from 967 no prob.
02-05-2008 12:47 PM
If you have disabled IGMP snooping then the switch will have to flood the multicast traffic to all ports. Which switch type is it ?
If you do a "sh ip igmp membership
Jon
02-05-2008 01:06 PM
6509 SUP720 MSFCv3 running IOS 12.2(18)SXD4
Client (10.239.173.251) VLAN configuration:
interface Vlan943
ip address 10.1x.yy.1 255.255.255.0
ip helper-address 10.xxx.yyy.zzz
ip pim dense-mode
end
With PIM enabled on the source vlan (967)
Channel/Group Reporter Uptime Exp. Flags Interface
*,239.1.7.2 0.0.0.0 00:26:33 stop 2SA Vl943
*,239.1.7.2 10.239.173.251 00:27:18 02:20 2A Vl947
*,239.1.7.2 0.0.0.0 03:42:21 stop 2SA Vl973
With PIM removed from vlan 967 the igmp membership is empty.
Thanks for the assistance Jon!
02-05-2008 01:17 PM
PIM being enabled on the interface is what sends out the IGMP queries. Without it there will be no igmp queries and so no igmp responses.
if you only needed to have multicast on vlan 967 then you can turn off PIM on the interface and enable the "igmp snooping querier" function on the 6500. The IGMP querier function then sends out IGMP queries.
Something has to query for members to report.
That explains your PIM/no PIM issue.
However it looks like you want to access that group from other vlans so you do need PIM on the interface.
But you also need IGMP snooping or else it will flood to all ports as said before.
I need to lab something up so i'll get back to you.
Jon
