Enabling SSH Connection on a WS-C2960-24TC-L Switch
Feb 5th, 2008
I have WS-C2960-24TC-L Switch with Software Ver 12.2(25)SEE3 and imge C2960-LANBASE-M currently on it. I want to enable SSH connections on the switch and believe I need to import the cryto image onto the switch. Is this right and if so how do I go about this. The switch is now live yet.
Thank You
Shaun
glen.grant Tue, 02/05/2008 - 14:54
Basically after you get the crypto code loaded it is as simple as the following .
Make sure box has a ip domain-name configured,if not create one.
conf t
crypto key gen rsa , hit enter
enter the key size you want to use and hit enter .
Then just add your transport input statements on your vty lines .
Verify key with the show crypto key my rsa command.
