InterCluster Trunk between CallManager 5.1 and 3.3
HELLO EVERYBODY.
Does anybody know, if it's possible to configure InterCluster Trunks between CallManager 5.1 and CallManager 3.3?
I already checked the documentation on both release, but for release 3.3 there are not field to fill as release 5.1, for instance Tunnel Protocol=Q.sig, Signnaling port=1720.
Any idea will be apreciated.
Walter Flores
gogasca Tue, 02/05/2008 - 21:09
Hola Walter,
That should work, try ICT non GK
For protocol Q.SIg you are referring to Annex M1 dont worry about that.
