ATA 186 - outgoing caller ID
Feb 5th, 2008
I have a ATA 186 running H323. The number associated with it works just fine when people call in. But when calling out, it will randomly use any number in my PRI as the caller ID. Any ideas?
tglidewell Mon, 03/17/2008 - 13:35
I tried your solution, but it didn't work. The change you are suggesting only differs the default setting in bits 29 & 30. And according to the link you sent, bits 29 & 30 are reserved. Any other ideas? The solution isn't critical, but something I would like to resolve. Thanks.
paolo bevilacqua Mon, 03/17/2008 - 13:37
  • Hall of Fame,
    Founding Member
How's you pri config and DP config ?
tglidewell Mon, 03/17/2008 - 13:47
Not sure exactly what you are asking for, but here's some of it;
dial-peer voice 1 pots
description ** T1 PRI pots dial-peer **
incoming called-number .T
direct-inward-dial
port 0/0/0:23
dial-peer voice 57 voip
corlist outgoing user-fax-XXXXX
description ATA H.323 FAX MODE dial-peer
destination-pattern XXXXXXXXXX
no modem passthrough
session target ipv4:XXX.XXX.XXX.XXX
codec g711ulaw
fax rate disable
dial-peer voice 58 pots
corlist outgoing call-fax-XXXXX
description ** T1 PRI pots dial-peer local for Fax**
destination-pattern 9[2-9]......
clid network-number XXXXXXXXXX
port 0/0/0:23
forward-digits 7
dial-peer voice 59 pots
description ** T1 PRI pots dial-peer LD for Fax **
destination-pattern 91[2-9].........
port 0/0/0:23
forward-digits 11
paolo bevilacqua Mon, 03/17/2008 - 15:11
  • Hall of Fame,
    Founding Member
Ok, it may be using different DP, some have a clid preset, other don't dial-peer. How can be that it uses a random number everytime ? What number do you want it to use?
If you want to see how your ata call is placed, take "debug isdn q931" with "term mon".
tglidewell Mon, 03/17/2008 - 15:17
Now you have lost me. I didn't setup the system, but I have to maintain it. Sometimes the outgoing CLID is correct, other times it goes out using another number within my DID range. I appriciate any help you can give.
paolo bevilacqua Mon, 03/17/2008 - 15:47
  • Hall of Fame,
    Founding Member
That is the strange thing, usually when you make a call out of a pri without specifying a DID number, or specifying a wrong one, telco switch will replace clid with main number, not random from did range.
So if you take "debug isdn q931" with "term mon" you will see in first place what number if any you're sending out with the ata. It gives you a very easy to read output.
Then from there one can see how to correct the problem.
