ISDN ppp negotiation strange issue
prasad.gsmc
I have one PRI line at india and one BRI line at the US.
We are able to connect from india to US. But when we try to call from US to India PRi number, We are getting the bellow error.
the show isdn active is not showing remote hostname (in either router).
PPP LCP negotiation itself not getting completed.
014103: Feb 6 00:14:25: Se1/0:0 LCP: TIMEout: State REQsent
014104: Feb 6 00:14:25: Se1/0:0 LCP: O CONFREQ [REQsent] id 148 len 10
014105: Feb 6 00:14:25: Se1/0:0 LCP: MagicNumber 0x0EF040AD (0x05060EF040AD
014122: Feb 6 00:14:34: Se1/1:29 LCP: TIMEout: State Listen
014123: Feb 6 00:14:34: Se1/1:29 PPP: Authorization NOT required
014124: Feb 6 00:14:34: Se1/1:29 PPP: No remote authentication for call-in
014125: Feb 6 00:14:34: Se1/1:29 LCP: O CONFREQ [Listen] id 36 len 10
014126: Feb 6 00:14:34: Se1/1:29 LCP: MagicNumber 0x0EF09BB2 (0x05060EF09BB2
014127: Feb 6 00:14:36: Se1/1:29 LCP: TIMEout: State REQsent
014128: Feb 6 00:14:36: Se1/1:29 LCP: O CONFREQ [REQsent] id 37 len 10
014129: Feb 6 00:14:36: Se1/1:29 LCP: MagicNumber 0x0EF09BB2 (0x05060EF09BB2)
india end configuration:-
interface Dialer1
ip address x.x.x.x
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer idle-timeout 7200
dialer caller 1234
dialer-group 1
no cdp enable
ppp authentication chap
end
US end configuraton:-
interface BRI1/1
description test
bandwidth 64
ip address x.x.xx
encapsulation ppp
dialer map ip x.x.x.x name test broadcast 01191xxxxx
dialer-group 1
isdn switch-type basic-5ess
isdn tei-negotiation first-call
isdn spid1 mynum1111 num2
isdn spid2 mynum1111 num1
isdn fast-rollover-delay 5
isdn calling-number num1
ppp multilink
I am able to connect and ping when dialer from india. but reverse its not even showing the other in host name in my show isdn active, and I am not able to ping.
Not applicable
Look at 'show isdn status'. If layer2 does show MULTIPLE_FRAME_ESTABLISHED or stay in that state then get 'debug isdn q921'. For example, try doing a 'shut,no shut' on the interface.
devisreagan
Hi Prasath,
Same configuraions work just fine for me ,make sure you dont have any access list enabled on the US end .Try adding dialer-list 1 protocol ip permit in global config mode & dialer map ip x.x.x.x name test 01191xxxxx (this should be the phone no of the other end)
Try to ping the pri interface ip to bring up the session .
if any issues send the debugs ppp negotiation out put of both side
Thaks for the comments,
Just recently the US telco updated that there could be a possible compression issue at switch side. I will update once i hear from them
