Linksys WRVS4400N IPSEC to Cisco Con. 3030
didyap Tue, 02/12/2008 - 09:26
Go to Configuration >> system >> events >> classes and add in auth, authdbg, IKE, IKEDBG, IPSEC, and IPSECDBG. Then go to Monitoring >> filterable event log and clear the log. At this point disconnect all instances of a connection to the linksys that is having a problem and wait for it to reconnect. Once reconnected, check to see if there are multiple instances. If yes, then check again the Linksys router's configuration.
