Weird Frame-Relay Issue
Feb 5th, 2008
Hopefully this is a very simple question to answer.
I am using IOS ver 12.4(10b) on a 3640 router with a NM-8A/S module.
When I go into the interaface configuration mode for one of the serial interfaces I cannot use and do not see the "frame-relay" command listed as one of the commands to use in the interface configuration mode.
I only see and can use the "frame-relay" commands in the gobal configuration mode.
What am I doing wrong or is there something I am missing about using the "frame-relay" commands in interface configuration mode in IOS ver 12.4?
Thanks In Advance
Edison Ortiz Tue, 02/05/2008 - 20:54
Did you type encapsulation frame-relay under the interface? Once you do, all the frame-relay commands should be available.
rawacisco Tue, 02/05/2008 - 21:58
Thanks for bringing this to my attention. The "encapsulation frame-relay" comand was one of the first commands I entered when configuring the serial interfaces but when I took a second look at the config I saw otherwise. Some kind of way I did not correctly save the running config when I reloaded the router.
Once I re-entered the "encapsulation frame-relay" command for the serial interfaces I could see and use the "frame-relay" commands in the interface configuration mode.
Thanks for help and the quick response
s.arunkumar Tue, 02/05/2008 - 20:55
Have u given "enacpsulation frame-relay"..
give this and check frame-relay command available or not..
rawacisco Tue, 02/05/2008 - 22:02
Once again I would like to thank you guys for your help and quick response with the issue.
To resolve this issue I had to re-enter the "encapsulation frame-relay" command on my serial interafaces and made sure that I saved the running config.
