Pix 7.2(1) mroute
Feb 5th, 2008
In my Pix(Pix 515E, image 7.2(1)) configuration I discovered strange thing.
When I use this command
"mroute If_Out"
, then wr mem and reload everything is ok, that means after reboot this command is still in running config.
Then, when I define
"name Net_Dmz2", then
"sh run | grep mroute", I can see output
"mroute Net_Dmz2 If_Out". Still ok.
The same is when I do wr mem, so in startup-config I can see
But the problem is when I do reload. Then after this command
"sh run | grep mroute" I can see nothing.
No mroute.
About as if the pix can't resolve symbolic name defined in name command.
Do you have any idea about this problem?
Many thanks.
