bandwidth management on Cisco switch
Feb 5th, 2008
Can some one help me to solve my issue? I have 2 cisco switches how can i manage the bandwidth on those switches. Also is this possible to do on 2900 and 3524xl series or i have to buy any other switch on which i can manage the bandwidth. Please help me to sort my problem.
Looking for your advice.
shivlu jain Sun, 02/17/2008 - 05:00
you ca use on 35XX switches the given below command for rate limiting
srr-queue bandwidth limit 75
shivlu
Mohamed Sobair Sun, 02/17/2008 - 11:27
Managing Bandwidth has lots of meaning, If you mean manage QoS on Switches, then Edison had provided a useful link you can use.
If you mean bandwidth managing (limitation) , then this is totally different.
Mohamed
