how to shut vty 5 15
Answered Question
Feb 6th, 2008
how we can shutdown the vty 5 to 15 on a router or L3 switch. any command ??
Correct Answer by mohammedmahmoud about 9 years 2 weeks ago
For some platforms (for example the 3560 switches) you can't remove any of the 16 VTYs (0-15), as a work around you can disable these lines via "no exec".
BR,
Mohammed Mahmoud.
Overall Rating: 4.5 (2 ratings)
Goutam Sanyal Wed, 02/06/2008 - 01:55
Hi Abhi,
The basic is use "no" to decline any command to a Cisco router.
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#line 5 15
No physical hardware support for line 5
Router(config)#no login
Thanks & Regards
Goutam
Pls rate if it works
mohammedmahmoud Wed, 02/06/2008 - 01:57
Kindly use "no line vty 5 15".
[edit] Goutam, the login command is used to enable password checking, using "no login" tells the router not to enable password checking on this line and to grant anyone access on this line without a password check.
BR,
Mohammed Mahmoud.
abhishekm4u Wed, 02/06/2008 - 02:08
hi ,
both commands not working
no line vty 5 15 shows below error and no login shows incomplete command.
kindly guide !
RJ-JPR-GUM-R1-64-6(config)#no line
RJ-JPR-GUM-R1-64-6(config)#no line vt
RJ-JPR-GUM-R1-64-6(config)#no line vty 5 15
% Can't delete last 16 VTY lines
RJ-JPR-GUM-R1-64-6(config)#line vt
RJ-JPR-GUM-R1-64-6(config)#line vty 5 15
RJ-JPR-GUM-R1-64(config-line)#no lo
RJ-JPR-GUM-R1-64(config-line)#no logi
RJ-JPR-GUM-R1-64(config-line)#no login
% Incomplete command.
Correct Answer
mohammedmahmoud Wed, 02/06/2008 - 02:15
BR,
Mohammed Mahmoud.
Goutam Sanyal Wed, 02/06/2008 - 02:15
Router# conf t
Router(config)#no line vty 5 15
Router(config)#
Its work and no need to put the command "no login"
With ur out-put is showing that 1s u disable the line & after u enableing it again.
Router(config)#no line vty 5 ?
<6-15> Last Line number
Goutam
pls rate if it works
