CSS Redirection problem
Feb 6th, 2008
I use a CSS 11500. I've problem of redirection HTTPS with Mozilla and Opera (it seems there are no problem with Internet Explorer).
Mozilla use a URL http://www.example.com:443/blabla instead of https://www.example.com/blabla.
Here my CSS configuration
ssl-proxy-list SSL-PROXY
ssl-server 20
ssl-server 20 cipher rsa-with-rc4-128-md5 XXXXXXXXXXXXXX
ssl-server 20 vip address X.X.X.X
ssl-server 20 rsacert certXXXX
ssl-server 20 rsakey keyXXXX
ssl-server 21
ssl-server 21 cipher rsa-with-rc4-128-md5 X.X.X.X 80
ssl-server 21 rsacert certXXX
ssl-server 21 rsakey keyXXX
ssl-server 21 vip address X.X.X.X
ssl-server 20 http-header prefix "SSL"
ssl-server 20 urlrewrite 1 www.example.com sslport 443 clearport 80
active
Thank you in advance for your help
Cedric
Gilles Dufour Wed, 02/06/2008 - 04:07
  • Cisco Employee,
I don't see why the response would be different for IE and mozilla.
Can you get us a sniff of the server traffic, to see what the redirect looks like.
Gilles.
cdicesare Thu, 02/07/2008 - 04:29
Indeed, the problem isn't the web navigator after to deep with tcpdump.
The problem is it misses the / at the end of the URL !
https://xxx.example.com/blabla => the redirect doesn't work => http://www.example.com:443/blabla
https://xxx.example.com/blabla/ => the redirect work !!
Our customer don't wish modify their webserver apache. It's possible to find a solution with the CSS ? With a specifiq redirector rule ?
Best Regards
Cédric
David Coupez Tue, 02/12/2008 - 07:33
And you should probably add a wildcard to ensure your redirect will work for every addresses used.
Gilles Dufour Tue, 02/12/2008 - 08:58
  • Cisco Employee,
NO !!!!!
do not put a wildcard as it would match the redirect link as well and you will enter in a loop.
Just copy it the way it is.
Gilles
CSS/CSM/ACE Guru
