02-06-2008 03:04 AM
Hi All,
I have a couple of questions around the CSS 11501 would be grateful if any gurus out there cud shed more light, here goes;
-Does the CSS support bridging between 2 vlans? In a similar way to the CSM. What command might be used to achieve this?
Thanks.
Kind Regards,
02-06-2008 04:11 AM
The CSS will bridge physical interfaces that belong to the same circuit vlan.
Nothing special to do. Just configure the same vlan on 2 physical interfaces.
Gilles.
02-06-2008 07:04 AM
Thanks for your response Giles.
Gotcha, further more ... so if CSS is L-2 adjacent to the servers do the servers have to have loopbacks created for the VIP?
I wud assume this wud be required as the CSS will only be re-writting the MAC address? Can you please shed more light here as well.
Cheers
02-06-2008 08:42 AM
no, there is no need to configure a loopback on the server.
By default the CSS does a destination ip re-write/nat using the server ip.
Even if they are adjacent.
However, if you want to avoid the ip nating, you can change the service type to transparent-cache.
Gilles.
