Outbound Option: MR PIM and EMT
Answered Question
Feb 6th, 2008
Hi All;
In Outbound, there is an EMT and MR PIM, the EMT communicate between the Dialer and the Campaign process at the rogger.
The question is: why to use EMT as there is MR PIM?
Bilal
Correct Answer by Riccardo Bua about 9 years 5 months ago
Hi Bilal,
oversimplifying here, PIM talks partially CSTA, common standard telephony application, protocol to OPC and a specific interface to the dialer, while EMT is part of the set of protocol overseeing the TCP connection yes.
HB = Heartbeats, keepalive exchanged to conferm socket is up.
Cheers,
Riccardo
Overall Rating: 5 (2 ratings)
antonio.vazquez Wed, 02/06/2008 - 03:32
  • Bronze, 100 points or more
what are trying to say with EMT?
Regards.
Riccardo Bua Wed, 02/06/2008 - 03:52
  • Cisco Employee,
Hi Bilal,
EMT is a class deployed over TCP to monitor and report different things, among others, TCP socket connection, heartbeats, alerts and so on, since those scenarios are common to most of the ICM processes you could understand why it was decided to include it both for the MR PG and the Dialer, not just to check on the HB exchange between the dialer and the assigned PG.
Nothing to worry about.
Cheers,
Riccardo
bilalghayad Wed, 02/06/2008 - 04:47
Hello Riccardo;
Your help always highly appreciated :) -
What meant by HB here?
I understood that EMT is used by the Dialer and the MR PG also, correct? So I can understand that alot (almost maybe) of ICM components support EMT which is used to talk between each others to retreive certain information like u mentioned, correct?
Here I have a question: does EMT mainly work for network level, while MR PIM work for interfaces (like telephony protocols and so on) level?
Bilal
Correct Answer
Riccardo Bua Wed, 02/06/2008 - 05:17
  • Cisco Employee,
Hi Bilal,
Cheers,
Riccardo
