standard vs enhanced IOS
Answered Question
Feb 6th, 2008
hi
can anybody guide me to find a way to compare the Standard and the enhanced version for the 12.3 ios ?
thanks
Correct Answer by Amit Singh about 9 years 4 months ago
The Enhanced IOS support the following:
• Dynamic Routing Protocols:
- Open Shortest Path First (OSPF)
- Enhanced IGRP (EIGRP)
- Border Gateway Protocol Version 4 (BGPv4)
• Policy-based Routing (PBR)
- Allows superior control by enabling flow redirection regardless of the routing protocol configured
• Protocol-Independent Multicast (PIM)
- For IP multicast routing within a network that enables the network to receive the multicast feed requested and for switches not participating in the multicast to be pruned-support for PIM sparse mode (PIM-SM), PIM dense mode (PIM-DM), and PIM sparse-dense mode
• Distance Vector Multicast Routing Protocol (DVMRP)
- Tunneling for interconnecting two multicast-enabled networks across non-multicast networks
• Private VLAN (PVLAN)
- Provides the ability to restrict communications between hosts at layer 2 through the use of primary and secondary VLANs
Please see the link below:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_qas09186a00801b0971.html
HTH, Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
bkoum Wed, 02/06/2008 - 03:51
hi
i was wrong about the ios version .actualy im interesting about the switch 3750 if there is any link....thanks again
Correct Answer
Amit Singh Wed, 02/06/2008 - 03:54
  • Cisco Employee,
-amit singh
