Config Global policy to use IPS (ASA 5520)
Answered Question
I get an error..ERROR: Policy map global_policy is already configured as a service policy when I try to set up the IPS. How do I correct this config?
--------Attempted Config Change-----------------
HO1ASA01# conf t
HO1ASA01(config)# access-list IPS permit ip any any
HO1ASA01(config)# class-map IPS-CLASS
HO1ASA01(config-cmap)# match access-list IPS
HO1ASA01(config-cmap)# policy-map IPS-POLICY
HO1ASA01(config-pmap)# class IPS-CLASS
HO1ASA01(config-pmap-c)# ips promiscuous fail-open
HO1ASA01(config-pmap-c)# service-policy IPS-POLICY global
HO1ASA01(config)#
HO1ASA01(config)#
------Running Config------------------
class-map IPS-CLASS
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 1024
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
class IPS-CLASS
service-policy global_policy global
Correct Answer by acomiskey about 9 years 1 month ago
Here is what it should look like...
inspect dns migrated_dns_map_1
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
class IPS-CLASS
Notice there is no "policy-map IPS-POLICY" command.
The reason you got the warning is becuase you already had the line "service-policy global_policy global" in the config. You did not have to re-enter it.
You need to get rid of "policy-map IPS-POLICY.".
Overall Rating: 4.5 (4 ratings)
acomiskey Wed, 02/06/2008 - 06:53
  • Green, 3000 points or more
Add the new class to the existing global_policy instead of creating a new policy.
class-map IPS-CLASS
class IPS-CLASS
Ok the config still looks the same, but this time instead of an error I get a warning.
WARNNING: Policy map global_policy is already configured as a service policy
class-map IPS-CLASS
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
class IPS-CLASS
Correct Answer
acomiskey Wed, 02/06/2008 - 12:13
Correct Answer
acomiskey Wed, 02/06/2008 - 12:18
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
class IPS-CLASS
pdriscoll Wed, 02/06/2008 - 15:09
There is an excellent post titled "How do you tell if an ASA-SSM-20 is actually running and filtering traffic?" posted on this same thread, dated Jan 31 2008 that I found extremely helpful on this subject.
