LMS Multi Server setup - best practice
Hi All
I am due to implement LMS 3 on a customer site very shortly. We will have to go down the multi server setup route due to the number of devices to be managed (3500+).
Could I use a virtual IP to link all 4 servers or do i stick with individual IPs for each box. Would a virtual IP impact on any area of LMS. Do I then assign the virtual IP as the SNMP host on the cisco boxes?
Overall Rating: 5 (1 ratings)
David Stanford Wed, 02/06/2008 - 07:45
  • Cisco Employee,
You'll need to use an individual IP address for each server and make sure each IP resolves to a hostname.
Virtual IP isn't supported and could impact numerous pieces of the app.
David Stanford Wed, 02/06/2008 - 12:41
  • Cisco Employee,
It depends on what you are doing on each server.
Common Services will be installed on each and I would suggest allowing each server to have access to snmp.
Each server will need to manage its devices even in a master/slave setup.
