Unprocessed CallerID on CME
Answered Question
Feb 6th, 2008
We have a trouble with CallerID. We receive it from the telco, but CallManagerExpress does not process it. Here's the debug log of a test call I made.
ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x010D
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9F8B0100A11002010102010080084D4F4E415354204A
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '450581xxxx'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '2505'
Plan:Unknown, Type:Unknown
013118: Feb 1 20:48:41.921: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x810D
ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x810D
ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x810D
ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x010D
ISDN Se0/0/0:23 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 0 call id 0xBA
%ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 450581xxxx N/A
ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x010D
Cause i = 0x8090 - Normal call clearing
%ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from 450581xxxx , call lasted 5 seconds
ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x810D
Feb 1 20:48:47.145: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x010D
See...
translates into
MONAST J
How can I tell CME to process those messages, and send them to the phones ?
Thank you!
Correct Answer by Paolo Bevilacqua about 9 years 3 weeks ago
Ok, I've found your previous message when the IE was not present at all. can you try:
voice service voip
qsig decode
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Wed, 02/06/2008 - 09:42
Hi, which switchtype have you confgured, and which exact IOS version ?
You should be able to see the name when all is allright.
olivier.bedard Wed, 02/06/2008 - 09:45
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(11)XJ4, RELEASE SOFTWARE (fc2)
isdn switch-type primary-5ess
As the telco's requirement.
Paolo Bevilacqua Wed, 02/06/2008 - 10:10
Whoops, I had forgot. Please configure
isdn supp-service name calling
under inteface.
Correct Answer
Paolo Bevilacqua Wed, 02/06/2008 - 10:58
voice service voip
qsig decode
