jason-calbert_2 Thu, 02/07/2008 - 07:55
  • Bronze, 100 points or more
Hello Allen,
I believe the VG248 is only FXS. You will need to connect your paging system to an FXO on a router. You would then create a route pattern of your 3 digits you want to send selecting your FXO port as the Gateway or Route List.
Hope this Helps
Jason
