Prefix in Mgcp
Feb 6th, 2008
We have a setup in which we are using 4 PRI lines from 3 different service providers.Two of them are sending us 5 digits and we are also sending the same to their end for both incoming and outgoing[with DID/DOD configured].But the 3rd SP wants us to send 10 digits.
Example : the service provider wants us to add a prefix of XXXXX to the etension number YYYY.Thus the resulting number number must be XXXXXYYYYY
We are using MGCP and CUCM 6.0.We have 5 digit extensions and how do i give a prefix only to calls going through this PRI line.
As because of this the DOD number is not flashed instead only the PILOT number is done.
regards
Kumar
Jaime Valencia Wed, 02/06/2008 - 11:42
  • Cisco Employee,
  • Hall of Fame,
    2011
you can add a prefix using a Route Pattern or in the route list configuration.
configure a route pattern exclusively for that provider and set the prefix only for it, on the other 2 route patterns keep them the same way
kumar3880 Wed, 02/06/2008 - 21:50
hi
Thanks for the response.Can you please let me know that if i add any translation-rule/profile in the gateway will this solve my requirement.[using MGCP]
regards
kumar
Jaime Valencia Thu, 02/07/2008 - 07:51
  • Cisco Employee,
  • Hall of Fame,
    2011
MGCP do not have the ability to do that, if you want to do it in the GW you need to use H323
