Auto Answer with Mute
Feb 6th, 2008
I have implemented a work around for paging over the phones. Basically, in strategic locations I have set up phones with a new DN set to auto answer.
It has been brought to my attention that people are abusing this and using it to evesdrop. Is there a way to set up the auto anser extesnion to auto answer on mute? 4.1.3
Jaime Valencia Thu, 02/07/2008 - 22:13
AFAIK it cannot be done, the mute enable/disable is not configurable from CCM, but from the phone itself (you need to press the button)
