Frame-relay question
Feb 6th, 2008
Following is sh frame-relay pvc
PVC Statistics for interface Serial0 (Frame Relay DTE)
DLCI = 170, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0.1
input pkts 0 output pkts 0 in bytes 0
out bytes 0 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
pvc create time 00:02:48, last time pvc status changed 00:02:46
PVC Statistics for interface Serial1 (Frame Relay DTE)
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = INACTIVE, INTERFACE = Serial1.1
pvc create time 00:02:49, last time pvc status changed 00:02:49the output
I got the office router, now not in use, and checked for Frame-relay. Both circuits were in use, but now one PVC=Deleted and other one is PVC=INACTIVE , why. Please help. Tahir
Istvan_Rabai Wed, 02/06/2008 - 10:23
Hi Tahir,
You need to configure the serial interfaces for frame-relay similarly to this:
interface serial0
no ip address
encapsulation frame-relay
no shutdown
interface serial0.1 point-to-point
ip address x.x.x.x x.x.x.x
frame-relay interface-dlci 170
no shutdown
interface serial1
no ip address
no shutdown
interface serial1.1 point-to-point
frame-relay interface-dlci 100
no shutdown
Is everything alright with your serial cabling connections?
Cheers:
Istvan
Edison Ortiz Wed, 02/06/2008 - 21:17
That information is what the router sees from the frame-relay switch.
DLCI 170 shows deleted because the frame-relay switch does not have that DLCI configured. You have configured in your serial0.1
DLCI 100 shows inactive which means the frame-relay switch has it configured but the remote-end is not up.
Is the frame-relay switch in a lab or are you getting this DLCI information from a provider?
__
Edison.
tahir1234 Sat, 02/09/2008 - 11:02
Hi Edison,
Deleted state Indicates that no LMIs are being received from the Frame Relay switch or that there is no service between the router and the Frame Relay switch.
Best regards, Tahir
Edison Ortiz Sat, 02/09/2008 - 13:28
Tahir,
Deleted means that you've configure a DLCI under the interface at your local router but the frame-relay switch has no information regarding that DLCI.
You can receive other DLCI information from the frame-relay switch, so you are receiving LMIs as long as the circuit is up.
