Corrupted Deterministic Network Enhancer
Feb 6th, 2008
Hello, I have found on multiple systems, that when using the Cisco VPN client 4.8.01.0300, from time to time, the DNE association will corrupt. Symptoms:
A client is able to establish a secure connection and is given a viable IP address. However, the client is unable to up or download any information. i.e. loading any website or downloading from a hosted app.
To solve this, a simple disable and re-enable of the DNE on the local area connection, seems to work. Not the virtual Cisco adapter, but the physical NIC.
My question is: what would cause the DNE to corrupt itself, allowing log-in, but disallowing traffic?
Thank you...
