ASA 5505 remote-vpn help
Feb 6th, 2008
Out-of-the box configuration. Changed the internal ip range, DHCP pool and ASDM config. Then I ran the VPN wizard to connect a VPN client. I cant establish a tunnel what so ever. Find attached the config and the log.
Thank you in advanced for you help
Niko
srue Wed, 02/06/2008 - 10:35
  • Blue, 1500 points or more
I pulled this off of a working config, 5505 7.2(3)
ip local pool vpnpool 10.x.y.1-10.x.y.10 mask 255.255.255.0
crypto ipsec transform-set AES256_SHA esp-aes-256 esp-sha-hmac
crypto dynamic-map DYNAMICMAP 5 set transform-set AES256_SHA
crypto dynamic-map DYNAMICMAP 5 set security-association lifetime seconds 7200
crypto map CRYPTOMAP 5 ipsec-isakmp dynamic DYNAMICMAP
crypto map CRYPTOMAP interface outside
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
group-policy GROUPPOLICYNAME internal
group-policy GROUPPOLICYNAME attributes
dns-server value 10.x.y.z
vpn-idle-timeout 120
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splittunnel_acl
default-domain value domain.org
split-dns value domain.org
tunnel-group VPNGROUPNAME type ipsec-ra
tunnel-group VPNGROUPNAME general-attributes
address-pool vpnpool
default-group-policy GROUPPOLICYNAME
tunnel-group VPNGROUPNAME ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication none
the very last line disables xauth...
niko.hartung Wed, 02/06/2008 - 11:15
Thanks for your quick response. I've tried to disable xauth already but no luck.
srue Wed, 02/06/2008 - 11:21
based on your configuration, you have to set the group name (in the cisco vpn client) to 10.0.0.0
is that really what you want?
you also don't have nat-t enabled, which might be causing issues.
if you don't want xauth, just add that last line under the tunnel-group ipsec attributes.
husycisco Wed, 02/06/2008 - 11:22
  • Gold, 750 points or more
Hi Niko
Attached config is a mess, attach the config you made after analyzing srue's sample RA-VPN config
niko.hartung Wed, 02/06/2008 - 12:07
