OSPF redistribution
Feb 6th, 2008
i am redistributing connected subnets into OSPF process with following command.
redistribute connected subnets.
All the routes / connected subnets are successfully distributing into OSPF, but there is a connected network on the device which i dont want to be ditributed into OSPF.
How can i exclude some static router from redistributing into OSPF ??
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 02/06/2008 - 11:38
  • Hall of Fame,
    Founding Member
You need to use a route-map.
Example:
connected route 192.168.1.0/24 and 192.168.2.0/24 blocked from redistribution while allowing 192.168.3.0/24 and 192.168.4.0/24
ip access-list standard CONNECTED->OSPF
permit 192.168.3.0 0.0.0.255
permit 192.168.4.0 0.0.0.255
route-map CONNECTED->OSPF
match ip address CONNECTED->OSPF
router ospf 1
redistribute connected subnets route-map CONNECTED->OSPF
HTH,
__
Edison.
Joseph W. Doherty Wed, 02/06/2008 - 18:48
Curious why you're redistributing connected subnets vs. making them OSPF interfaces.
Redistribution makes them externals. If you're concerned about peering, you can make interfaces OSPF passive.
